We here in the States always call it a drive shaft, but even Toyota calls it a propeller shaft. Until the Propeller Shaft recall on the Tundras, I had never heard of the term propeller shaft...so, I did a little research on the web and guess what? The drive shaft really is supposed to be called a propeller shaft!:ugh3: (I think I read that propeller shaft is a british term while we in the US call it a drive shaft)Are you sure you're looking at the 2WD stuff?
I thought the propeller shaft was the front driveshaft. Since you don't have 4wd, you wouldn't have a propeller shaft.....
the 4 bolts that hold it on at each end.So, which bolts?
I've seen it as propeller shaft for as long as I can remember in formal use. (propeller shaft because it is used to propel the vehicle)We here in the States always call it a drive shaft, but even Toyota calls it a propeller shaft. Until the Propeller Shaft recall on the Tundras, I had never heard of the term propeller shaft...so, I did a little research on the web and guess what? The drive shaft really is supposed to be called a propeller shaft!:ugh3: (I think I read that propeller shaft is a british term while we in the US call it a drive shaft)
Who would have thunk it!:hammer:
irregardless of what you call it, thanks for posting that link! I'm gonna bookmark that.http://www.ncttora.com/fsm/05+/local files/repair.html
Use your "find on this page" feature, type in *propeller*
Great stuff!!irregardless of what you call it, thanks for posting that link! I'm gonna bookmark that.
