Listen to this man, he knows what he is talking about.88 LE said:Personally I would flush mount them in the A pillars (the plastic trim that runs down the side of the windshield).
Depending on the depth of your tweeters they may not flush mount, but you can take care of that with some body filler and/or fiberglass. In other words go custom.
Play around with the position of the tweeters and see what sounds best to you.
As for components (2 way or 3 way) vs. a 3 or 4 way coaxial, I'd go with components. I highly suggest using a amp on them.
Here's the thing with sound. What you have to compare stuff to is basically a stock system, so pretty much anything is going to sound better the closer you get to "appropriate" positioning. Appropriate positioning is usually common in two places, kick panels in the foot well (to equalize pathlenght difference; you usually put both the woofer an tweeter of the comp set here though some just put the woofer there), or another place would be what 88 mentioned: the A pillars at ear/eye level (this is to improve imaging making it seem like the music you are listening to is coming from out on the hood of the car). I'm sure you can achieve just as good or better results by experiementing, but these two locations are typically the defaults.
Other locations like the ones mentioned (sail panels or even high up in the door panels; i've seen people mount them in their dash and reflect off the windsheild) do work, as everyone has different taste in sound, Get some double sided tape and play around with what sounds good in your car.
