where is the coil in the distributor to a 3sge 1st gen? pics if possible!
T The Black Camry · Registered Joined Sep 11, 2005 · 159 Posts Discussion Starter · #1 · Jan 3, 2006 Only show this user where is the coil in the distributor to a 3sge 1st gen? pics if possible!
A alltracman78 · Alltrack Wannabe Joined Aug 23, 2005 · 639 Posts #2 · Jan 3, 2006 Only show this user I believe in a 1st g 3SGE the coil is separate from the dist. It should be on the firewall right near the brake booster.
P Pineapple · Registered 1990 Celica GTS Joined Apr 22, 2004 · 2,714 Posts #3 · Jan 3, 2006 Only show this user If disturbutor cap got 4 wires, coil is inside. If it got 5 wires, follow the center one to the coil.
A alltracman78 · Alltrack Wannabe Joined Aug 23, 2005 · 639 Posts #4 · Jan 4, 2006 Only show this user Good point...
T The Black Camry · Registered Joined Sep 11, 2005 · 159 Posts Discussion Starter · #5 · Jan 5, 2006 Only show this user Im doing an engine swap from the 3sfe to the 3sge and i needed to know where its at. andhow does it connect to the wiring harness. pics perfered.
