1 - 19 of 19 Posts
Hi guys, noob here, first post. Two questions I need help with. I have an S2000 so I have no clue what brands you guys use on your Toyotas' or which are any good for that matter.
I've searched and I found a bit of info on the plugs but nothing on the pads.
My dad has an 05' V6 LE and needs his brake pads changed. Apparently the dealer wants $155 for all four corners!! Thats insane!!
What pads do you guys use? And if you use OEM, where do you guys buy them at?
Also, is there a good cheap site where you guys order your spark plugs from? Is sparkplugs.com a good site?
Any help is appreciated, thanks.
2010 Camry SE V6
2021 Toyota Camry TRD
The plugs don't have to be replaced until about 100K plus miles because they're long-life iridium tipped plugs, so cross them off your list for now. And just use OEM pads. You can purchase them from a dealer.
Maven
OEM Toyota pads are really very good but if the pricing is too high, go to the local parts store for some Wagners. They aren't as clean as the oem, but the price doesn't compare either.
'07 XLE 4 cyl.
i believe you need to get the Mark AK PA533 pads...the other pads are for the SE/XLE's. for the rears, look at your VIN number... if there's a J for the first number, you will need the Japan built pads; otherwise you will need the USA built pads.
autozone has CMAX pads that are 60 bucks for the front and like 55 for the rears i think for gen 7....
ceramic pads with nitrile rubber backing and actually a decent pad.... also quite!
comes with shims and a little bit of lube... ;)
and ofcourse there lifetime warranty :)
when the pads finish
bring them in...
new ones
free
for
life....
i should work for autozone...
oh wait i effin do... FML
Sedan Life
2003 Lexus ES300
OEM is best. always.
id rather do it right the first time than cheap out and bitch later when the brakes squeak and leave tons if dust on the wheels.
1 - 19 of 19 Posts
