My 07 (about 80,000KM /50,000M)Corolla is due for another oil change, and service shop of local Toyota dealer recommends the following services, and I am wondering what services are worth to do...
Power Steering Flush (every 56000KM): $99.95
Brake Fluid Flush (every 64,000KM): $89.95
Emission Service (every 48,000KM): $179.95
A/C Service (every 24 months): $93.95
Auto Trans Flush (every 48 to 96 months): $179.95(Dexron) $229.95 (Type T4) 269.95 (Type WS)
Engine Tune Up Plug/air & pcv valve(every 480000: From $179.95
I have been doing the Lubrication Service (oil change) with this dealer from day 1, and I did their maintenance service once when the car is at 45000KM/28000M.
Lubrication Service $49.95
- Replace engine oil filter
- Remove and inspect air filter elements
- Lubricate locks, latches, and hinges
- Confirm lights, horn and wipers function properly
- Check coolant, brake and washer fluid levels
- Check tires and adjust tire pressure (as required)
Maintenance Service $159.95
- Includes MOA engine protection
- Remove and inspect air filter and cabin/pollen filter
- Inspect drive belts for damage and adjust belt tension (if required)
- Check steering gear box, linkage and shock absorbers for looseness, damage, and leakage
- Inspect ball joints and dust covers,drive shaft and steering rack boots
chassis nuts and bolts for looseness, damage or leakage
- Remove wheel and brake drum, check pad/shoe thickness
- Examine brake calipers, wheel cylinders, and brake lines for proper function, leak or damage
- Rotate tires, examine, and damage or wear, check tire pressure (as required)
Thanks for help!
Thanks for help!
