im doing a valve cover gasket change and im a little confused which way the plug seals go. ive watched several videos and have seen the seals put in two different directions.which way is right?open end with spring up or down when installing from inside of valve cover ? the sticky here shows the seal oriented so its a easy slide over plug tube.right or wrong ?
