You can tell if it is the valve guides very easily. Watch the tailpipe as you start. If you get a big puff of smoke, it is the guides. Generally though, you will not get valve guides causing smoke while running normally. The combustion chamber us under pressure almost all of the time during the 4 cycles, only being neutral (barely) during the intake stroke. However, from your vehicle sitting and not running, the oil pooled at the valves will run down the valve stems, dripping into the combustion chamber. When you spark up, it burns off this oil, causing a cloud of smoke for a few seconds until the engine has burned the oil off. I would not think it is the valve guides, rather the oil scraper on one or more pistons is worn, or the cylinders are ovaled out. This would cause oil to get in on top of the piston on each downward stroke, thereby getting into the combustion chamber. Hard to tell without a teardown and rebuild. I'd say "live with it!". I'd also suggest not using Sea Foam or another engine cleaner, it may clear away the varnish or sludge taht is minimizing this issue. I've made that mistake myself.
D'mon
:chug:
