1 - 8 of 8 Posts
87 Camry Wgn 232k
RSB: Install on Wagon w/o RSB?
Hi All,
Can a Whiteline rear anti-sway bar be installed on GEN2 Camry wagons that were not originally equiped with one?
If a Whiteline RSB can't be added, can a Toyota RSB be added?
Thanks!
3s-gte in a Camry?!?
'89 Camry Alltrac
chasman said:
Hi All,
Thanks!
Install the factory one first. Get all the parts from the junkyard:
Bolts, brackets, bushings, endlinks and nuts....
If that doesn't improve the handling enough, then buy the Whiteline bar and install it. You can't install the Whiteline bar without a lot of of the stock parts (brackets, endlinks and bolts/nuts).
-Charlie
87 Camry Wgn 232k
Thanks for the good news Charlie!
-Charlie
You made my day!
Pochacco Owns Me
endlinks are easy to get 14mm sockets and bushing brackets are also 14mm bolts. try to get the metal end links seems like those are rare as i only seen 2 so far and i got them both from the junk yard :) while there's a million of plastic ones but those works too unless you drive like a bat out of hell on corners
87 Camry Wgn 232k
87 Wagon: Used OEM RSB $?
Hi Charlie,
-Charlie
About how much should all this cost at the JY?
Thanks again!
87 Camry Wgn 232k
Discussion Starter #6
Thanks for the Tip atobe!
Pochacco Owns Me
my junk yard charged me 8$ for the swaybar
87 Camry Wgn 232k
Discussion Starter #8
Complete RSB Assembly: Which JY?
Excellent price!
So far, I'm not having any luck locating a complete rear anti-sway bar assembly (including all bolts, brackets, bushings, metal endlinks, and nuts).
Any suggestions?
Thanks!
1 - 8 of 8 Posts
