1 - 2 of 2 Posts
97 T100 SR5 4X4
I'm wondering what lifts people are using and what issues they have run into. I unfortunately have a Trailmaster (Not by choice but by purchase). I have so far found that the bump stops are completely useless. The drop backets have shifted and screwed my alignment. The rear blocks have amplified the axle wrap and I have replaced the leaf spring center pins. I am currently planing on replacing the rear springs with custom full lift and maybe four linking the front with a solid axle. Any ideas and info. Thanks
I have a 1996 T100 4x4 Extra cab with 38” Super Swamper TSL’s. 4” Superlift suspension and 3” body lift. The body lift is 3” full aluminum round stock. The front drop brackets are one solid piece. So no alignment issue. I have 4” rear cast blocks but I cut a piece of ¼” flat stock to go under each block. This keeps the axle perch from wearing into the webbing of the block. I owned a 1986 Toyota 4x4 and installed a 4” Trailmaster lift. I corrected the problems with the T100.
1 - 2 of 2 Posts
