1 - 5 of 5 Posts
'06 Seinna XLE AWD
I got some RAV4 17" steelies to mount my snows on. They came with a set of almost new 225/65R17 Goodyear Assurance all seasons. Will they fit my 2006 XLE AWD with no issues. I know the factory size is 225/60R17.
2015 Sienna / 2018 RAV4
You'll need to mentally re-calibrate your speed slightly.
You have two differences from stock. We also have an '18 RAV4, and the offset on the 17" wheels is 39 mm IIRC. That puts them slightly outboard from your Gen-II Sienna? Sorry, don't have my specs with me. Plus a bit taller tire. There is probably room, but you are getting close.
Reactions: shortlid
Sienna offset is either +45 or +50, depending on trim level:
Looks like an '18 Rav4 has +45:
I don't believe that data is correct. When the Gen 4 RAV was introduced (2013), some 17" alloy wheels were 45mm. The following year they went to 39. The 18" wheels are 45, but they are also a half inch wider. I purchased 2015 17" alloy wheels for winter duty and they are 39 mm, as are the 17" alloy wheels on her 2018.
Now.... the accuracy of their data on the 17" STEEL wheels is an unknown. I know they are narrower (6.5") than the alloy wheels (7"), but even Hollander Transwheel does not list offset.
1 - 5 of 5 Posts
