1 - 6 of 6 Posts
VIP
95 MR2
Will my 1991 Toyota MR2 radio fit in my 1995 Previa??
The MR2 radio is the regular casette/AM/FM NON premium unit
The previa radio is also a regular Casette/AM/FM NON premium unit
Any suggestions or comments??
Not so Noob now!
I don't think you will have any problems doing it. The wiring harness should be the same. You will most likely need to swap the mounting brackets.
Highlander
It will be an exact fit, all you need is to transplant the radio and use same brackets from the car. However, if the radio from the MR2 is of the premium version, then it will not work since the harness is different.
1 - 6 of 6 Posts
