1 - 8 of 8 Posts
Hi Guys,
First post here. I bought a 2004 Sienna LE recently, and I am now searching for winter rims. There is a local sale, the seller has four Toyota Steel Rims from her 98-01 V6 Camry, the description is: "4 (5 bolt, 16" centers)".
I am wondering will these fit my 2004 Sienna?
From an online bolt pattern site, it seems that Camry run 14" rims, and Camry/Solaras run 16 rims. However, since her wheels are 16", so it seems her wheels should fit my Sienna? Is this correct?
CAMRY 92-on 14 X 6 5X114.3 12mmX1.5 60.1 H
CAMRY SOLARA 99-on 16 X 6 5X114.3 12mmX1.5 60.1 H
Thanks!
Hexar
Discussion Starter · #2 ·
Just realized that my Sienna has TPMS. What do I need to have my winter tires mounted? I have four bare winter tires (215/65/R16 tires not mounted), if I buy these 16 rims, what other equipments will I need? Special stems?
Thanks!
'06 Seinna XLE AWD, '04 Highlander V6 4WD
www.tirerack.com look at bolt pattern, offset, and center bore if the same should bolt up no problem!
Hi Guys,
Thanks!
Hexar
Sorry I can't help you, but would you mind posting a link to the bolt pattern website. I have a set of wheels and tires I need to sell and am wondering what other vehicles they could fit on
thanks
05 Tundra
If you just have rubber valve stems you tire moniter system uses the ABS to count tire rotation, so you would just need new rubber stems, Darrin
Discussion Starter · #6 ·
thanks
Sure, I was not sure if there is a forum policy where we cannot post outside links, that was why I did not post the link.
http://www.discountedwheelwarehouse.com/Toyota___Vehicle_Bolt_Pattern_Reference.cfm
From the same site, you can search for bolt patterns for other vehicles.
Discussion Starter · #8 ·
Thanks! Your link did not work, but I found the information from tirerack: where 215 tires can be mounted on rims 6" to 7.5" wide.
I bought the 4 steel rims for $75, they are CMC 7 HN25, whatever that means. The previous owner used these on her V6 Camry, so I guess the offset should be correct.
1 - 8 of 8 Posts
