1 - 16 of 16 Posts
Hi All,
I am looking at a 2009 TH AWD V6 with 54,500 miles for $12,800 and a 2005 TH AWD with 67,000 for $9,500. Both appear lightly used and garaged.
I've not owned a TH before and don't know which to choose. I am looking for a good daily driver that can do some light adventuring on the weekends, such as fire roads once a month and up to the Sierras for skiing a few times a year. Personally, I am leaning toward the 2005 for the price and because it was a later model in that generation.
Is there anything I should look out for in particular when I inspect these guys this weekend?
What is fire roads?
Highlander is NOT an outdoor car. It's a family hauler. That's it. No adventure in it. Made for city roads, maybe some lite gravel and mud. Does not do well on steep hills/unpaved roads.
You want adventure car, look at 4Runner or FJ Cruiser.
Your links don't work.
Thanks ukrkoz for the response. Fire roads are just dirt roads to camping sites, etc. I don't think I need anything as heavy duty as a 4Runner. I had an old Audi station wagon that got me around just fine on those roads and up in the snow. A daily driver is my main goal. Anything I need to look at when inspecting?
05 camry 07 tacoma
Have a complete pre purchase inspection done by pro mechanic.
Engine,trans,suspension etc.
Gravel is fine, don't go into mud.
Highlander Limited
There are many reasons why I would avoid the 1St Gens. Number one is that the v6 uses a timing belt. I would also avoid the 08-10 years, but it's mostly due to preference on my part. As far as issues goes it's no different than most other cars. I will say there are far less serious problems on these vs a Kia or Chevy LOL. As stated above the all wheel drive system sucks, but with good tires it does OK with the help of the traction control system.
Inspect vvt and oil cooler hoses....they tend to blow and should be replaced with hard lines
Inspect transfer case and transmission for leaks
My '08 is a very capable off-roader as long as I dont exceed its limit. I wouldnt bother with the 1st gen
Too old and unknowns
Too low mileage for the year would be an issue.
I’d get the one that looks like and has proof it was well maintained. That includes how many dings it has in the body. If you care about your car you park away from the crowds.
i just picked up a 2011 Limited, with 75,000 miles on it and it looks new. No hesitation buying it, but I travelled 3.5 hours in rain and snow to get it!
Get the 09. All of the issues are well known and can be fixed easily (minus the rear hatch hinge issue). Fire roads are no problem for Highlanders. The rubber VVTi and oil cooler lines should be replaced with all metal lines. Toyota's recall only swapped it with another rubber hose. Just spend the extra money and get a full metal line. Most people forget to do the maintenance of the transfer case and rear differential for the AWD model. A simple fluid change will go a long way in keeping everything working.
Highlander(s)
You have a dual post. Perhaps the mod can combine them. I responded in your other thread. But honestly now after reading this post you started I would skip the HL and get a 4Runner
Highlander Limited
um, the 3.5L V6 uses a timing CHAIN.
You are correct, but no one said it didn't LOL. I did mention that the 1St Gen v6 motors have a timing BELT tho. Perhaps you didn't read that right?
LOL what a strange comment. Obviously all used cars are unknown and you never know. I bought my 09 back in 2018 with 57,000 miles. One owner no accidents and mint condition and all service was done at a Lexus dealership. It has been great so far. You can get good deals and mitigate risk. OP has a budget to work with hence he’s asking around.
1 - 16 of 16 Posts
