Hi,
I have a 1994 Camry LE, 4cyl., with only 14inch steel rims and want to have aluminum rims now (because I have one set of 15inch summer tires).
I saw a used set of Mazda 626 rim (15inch) forsale:
with the following specs (5x114.3mm / 12x1.5 Lugnut / 59.60mm Bore)
My Camry specs: (5x114.3mm / 12x1.5 Lugnut / 60.06mm Bore)
So the Mazda has a slightly smaller bore (59.60mm).
*** Will this smaller bore too tight for my camry's bore ? (I think slightly bigger is fine, but not for slightly smaller) ?
I'd appreciate your help.
Thank you all.
Thank you all.
