1 - 7 of 7 Posts
2016 Toyota Land Cruiser
Hi All,
I am looking to purchase these 2019 Lexus LX 570 wheels for my 2016 Land Cruiser, and was wondering if they will fit properly. Here are the details:
Size - 21”x8.5”
Diameter - 21”
Width - 8.5”
Lugs - 5
Bolt Pattern - 150mm
Offset - 54mm
Thanks in advance!
342913
Discussion Starter · #3 ·
It looks like they would but try plugging in the numbers from both in this calc.
Thank you. Any idea how to find the aspect ratio?
Super Moderator
1995 T100 2WD & 1993 MR2
Aspect ratio is the center number on the tire size.
This is the OEM tire on the Lexus: 275/50R/21 Aspect Ratio is 50
Here's the closest wheel/Tire combo offered on the LC: 285/50ZR20 Aspect ratio is 50
You can do comparisons on the site I sent or one like this.
The LC 20" is #1 and the Lexus is tire #2
Not much difference.
OR:
Aspect ratio is simply identified as a percentage of the section height divided by the section width. In the example below, the aspect ratio of the tire is 70 percent, so the section height of tire will be 129.5mm. The higher the aspect ratio, the taller the tire sidewall.
I did the opposite, added 18" LandCruiser / Tundra TRD Pro wheels to my LX570, they fit perfect. There aren't many tire options in the 21" size so as long as you're OK with that I'd say go for it.
342962
1 - 7 of 7 Posts
