i'm going to change out my dino trans fluid for valvoline syntethic and i'd like to do it all at the same time without doing 3 changes over the next week.
what if i pull the 3/8"? rubber hose off the pipe coming straight out of the trans and run it into a catch bucket and put a temporary hose (not sure of the diameter till i remove it but looks to be about 3/8") from the trans pipe down into a new gallon of valvoline? start it up and let it run until the new 'supply' container is empty, turn it off, put another gallon of fluid up to the hose and run it until the fluild changes color?
i assume it will take about 8 or 9 qts to do to this.
i don't know if the trans pump has enough pull to pull the fluid out of the supply container or not though as the other times i've seen something close to this, they just refill through the dip stick but that's gotta take alot longer that way. just curious what you all think.
(i just dropped the pan a few hundred miles ago and put a new filter on it so that's why i didn't mention doing it again this time.)
thanks
tony
thanks
tony
