well i have them on my windows get the clip ones just slide them in between were the rubber is and then put the clips in so the window can close ..the ones with adhesive leave marks around the door frame if you wanted to take them off..clips are better no mess and if you don't like them there easy to take off you should try get ones that are the right size for your car because they could be to big or to small watch that...
