Hi,
I just changed the windshield wiper blades on my friend's 2007 Camry LE. Then I noticed the windshield wiper arm on the passenger side was resting a bit too low and I had to pry it up a little bit to get the arm to come out fully. I was able to change the blades with no trouble. But when I started the engine and turned on the wipers on, the passenger side arm was hitting the top of the engine hood when it went down to its lowest position. Otherwise the arms were working great and moving in full swing.
I noticed there's a nut holding the arm in place at its base, and maybe I can loosen this nut to calibrate the arm position? I'm guessing this is an easy job to do with a wrench? Has anyone had the same problem? I'd appreciate any input :smile:
