1 - 12 of 12 Posts
1996 Corolla
I have a 1996 Corolla and the front wipers for months have been going really slow at all speeds. So today I bought a new motor and installed it. It is stilll going slow. What else could be the problem. AMy roomate mentioning something about lubing the control arms. Can you do that? Any help would be appreciated cause I don't want to bring it to the garage.
2015 Toyota Camry V6 XLE
maybe wiper blades too big?? I am not sure if that's also a cause. but the proper blades are 18" passenger side and 20" for driver side
I had that problem a while ago. It is a lubrication problem. Basically you need to remove the front plastic trim just below the windshield base to access the mechanism of the wiper arms. You then need to grease it. It is not hard at all to do. It consists of removing a couple of philips screws and yank out the plastic trim. You might need to open the hood to have easy access.
I had this same problem for one or two years and thought it was the wiper motors or rust in the wiper mechanism. However, it turned out that my alternator was no longer functioning correctly in order to completely charge the battery. (I discovered this when I was driving one day and suddenly the radio, headlights, and speedometer all turned off for a couple of seconds) I had to get the alternator replaced and the battery as well and suddenly the wipers were working fast again.
95 corolla
:) Wipers on my 95 Rolla
"lubing the control arms" is a good method, because the motor is new, the problem maybe the joint, you can lube them first.
I would do the same Lube the control arms. Last week i bought some Bosch Wipers
Evolution Wiper Blades
Step up to Bosch patented bracketless technology, for exceptional all-weather visibility and DirectConnect™ easy one-step installation.
Bought passenger side 20" and Tried 19" on the driver side and it works fine!
The one better then above is:
ICON Wiper Blades
Patented bracketless OE technology with fx dual rubber for ultimate all-season performance that lasts up to 20% longer than other premium wiper blades.
1 - 12 of 12 Posts
