Is there any wire from the harness connected to the multiplex network body ECU (located behind the automatic high beam button panel, beside the steering column) or the junction box (located beside the driver's footwell) that is connected to the wireless door lock buzzer? I'm trying to hook up a module to use back the factory buzzer as it is currently set up to the horn (tapped into the horn wiring under the steering wheel) instead.
