Hey, so I am just about to start doing my first swap. I am replacing the 3sge in a 91 JDM MR2 with a JDM 3sgte. I was looking it all over before I started to pull it apart to make sure that I know what I all have to do and that I am going to be capable of doing the swap sucessfully. Everything looks like it should be pretty straight forward however I noticed that on the body wire harness there isn't the two clips that connect to the fuel pump and injector resistor packs. I know that this swap has been done many times before so there has got to be a way that this is solved. It is the two resistors that sit by the fuse box in the engine compartment. Any help would be great.
