1 - 4 of 4 Posts
Gen 2 Pimp
Here are my particulars:
I have a 91 Camry
Australian Headlights with fog lights
ES 250 Dash with fog light button
Here is my problem:
I want to wire my aussie fog lights up to the Lexus Fog Light button.
Here is what it looks like:
There are four wires coming out of the fog light button
One green with a orange stripe
One solid green
One red with black stripe
One red with blue stripe
I already have a power source and know to ground it, but I don't know what to do with these wires. What are they each for and could anyone give me some direction.
Thanks in advance for help.
Matt
poor college student
i would guess that there are 4 wires becuase there are 2 foglights. positive and negative for each.
i would also surmise that the reds are for positive and the greens are for negative..
guess and check?
Grenaded piston
One solid green
This is my guess:
Red with black stripe = output to foglight
Red with blue stripe = output to foglight
Solid green = ground or constant (+12V)
green with orange stripe = constant (+12V) or ground
If you have a DMM you can check for continuity with the switch on/off.
You also need to wire up a relay.
Not so Noob now!
Hold that thought guys.
Two wires are the switch and the other two are for the switch illumination. (Dash lighting) Get a continuity tester, with the switch off, use that to figure out which two are the bulb. That would leave the other two leads for the switch. & yes you would need a relay unless your car came with fogs originally.
1 - 4 of 4 Posts
