smog problem
The problem is that I can not hold a high idle , the rpm wil surge between 1200 - 2700 rpm and the smog tech can not get the rpm to hold steady. The smog equipment will not register and will kick off and not let the test go on. I cant find a vac leak and the truck will hold a steady cold high idle , but will surge if taken from the cold high idle (about 1500 rpm) to 2700 rpm .Might this be the tps ? Any help is welcome.
