My son has a 95 tacoma that is hard to start after it gets hot. If you shut it off and restart it right away it's fine but if you let it set for about 15 minutes it turns over but no start. It also hesitates more as it gets hotter. Replaced fuel pump and filter. No codes present. It seems to get worse as the air temp rises and better on cooler days. It had been to the shop twice and the first time they said the timing was off one tooth, the next time they found a cracked vacuum hose.:headbang:
