1 - 6 of 6 Posts
ok so. WOT feels like its not giving much power. half open seems to give me more acceleration.. 200k+ miles and ebay SRI. i have the MAF in the nipple of the SRI but since its ebay peice of s, the sensor fits in the hole but will fall out so i used electrical tape and taped it on. so yeah..
anyone have any ideas?
would it be the MAF not working right in the ebay sri, or fuel pump went bad ? =\
thanks for ur time.
oh and this happens on the highway or from stop
mixed bag 'o vehicles
so did this problems start after you installed the special ebay SRI? sounds like a sensor isnt reading correctly.
i dont think its a fuel pump because the car would probably just stall thinking its getting fuel when its not.
TN Pussy Man
Camry
^ I agree- there's probably nothing wrong with the fuel pump
as well, when you said that the maf sensor is held in with electrical tape, there is a definate possiblity of a vacuum leak which will make the sensor readings incorrect
is there any way to test to see if its leaking besides trying to feel it ? and if its leaking, would it be comming out or air going into the sri ?
thanks
TN Pussy Man
Camry
extra air will be going in
to test, you can spray some throttlebody cleaner around the hole area
if the revs go up, then you have a leak
Run a bottle of fuel injector cleaner while you're at it.
1 - 6 of 6 Posts
