1 - 3 of 3 Posts
AVAILABLE FOR PRE-ORDER NOW!
Have you been wanting to upgrade your 9005 High Beam bulbs to LEDs, but didn't want to be "That Guy" with the DRLs that are basically just High Beams because your LEDs can't dim? Well, worry no more, the solution you've been waiting for is almost here!
XenonDepot has developed a new LED Driver for our Xtreme PRO 9005 LED Kits, which allows the LED Bulb to dim in DRL mode to something more suited for daytime driving. Best of all - you get absolutely no flickering in this new setup. That's right - you get a true High Beam/DRL combination, with bright white light in both modes.
The Xtreme PRO Daytime Running Light LED Driver is a simple, 1:1 replacement for the existing driver (and any CANBUS/anti-flicker components you currently have installed) if you already have one of our 9005 LED Kits. It can be used instead of the regular LED driver that comes with the kit if you are getting these lights for the first time.
Check out the video below for a look at the difference the new DRL LED Driver makes and how simple it is to switch out from an existing installation.
Do you plan to offer the DRL LED driver and the 9005 Xtreme LED Pro headlight as a kit? Or just buy the headlight and new driver separately?
1 - 3 of 3 Posts
About this Discussion
2 Participants
XenonDepot
Toyota Nation Forum
Full Forum Listing
