is the abs light illuminates in the cluster?
When you removed it from the vehicle, did you disconnect it from the proportion valve or from the abs block?
Check each wheel to see if the hoses have air bubbles.
How does the brake pedal travel feel? Squishy or longer travel to stop? Check the master cylinder. The o ring may be leaking there.
