EDIT: Here are the steps for performing Zero Point Calibration taken from the 5th Gen 4Runner Repair Manual. The steps for FJ Cruisers will probably be very similar
IF your 4Runner is equipped with either DAC or Crawl Control, you must complete steps 4 and/or 5 or you will get a DTC and the slip indicator will always be lit.
I highly recommend this calibration if you think the VSC on your 4Runner kicks in too much, before or after lift. Mine was overreacting both before and after the lift, now for daily driving don't even know its there.
PERFORM YAW RATE AND ACCELERATION SENSOR AND STEERING ANGLE SENSOR ZERO POINT CALIBRATION (When Using SST Check Wire)
NOTICE:
* While obtaining the zero points, keep the vehicle stationary and do not vibrate, tilt, move, or shake it (do not start the engine).
* Be sure to perform this procedure on a level surface (with an inclination of less than 1%).
(a) Clear the zero point calibration data.
(1) Turn the ignition switch off.
(2) Check that the steering wheel is centered.
(3) Check that the shift lever is in P.
(4) Turn the ignition switch to ON.
(5) The ABS warning light and slip indicator light come on for 3 seconds to indicate that the initial check is completed.
(6) Using SST, connect and disconnect terminals 12 (TS) and 4 (CG) of the DLC3 4 times or more within 8 seconds.
Front view of DLC3
(7) Check that the slip indicator light comes on.
(b) Perform zero point calibration of the yaw rate and acceleration sensor.
NOTICE:
* DTCs 36 (Zero Point Calibration of Yaw Rate Sensor Undone) and 39 (Zero Point Calibration of Acceleration Sensor Undone) are stored if the shift lever is not in P.
* If a DTC is output that indicates zero point calibration is incomplete, repeat the procedure starting at the step for clearing the zero point calibration data and system information.
(4) Using SST, connect terminals 12 (TS) and 4 (CG) of the DLC3.
Front view of DLC3
(5) Turn the ignition switch to ON.
(6) Keep the vehicle stationary on a level surface for 5 seconds or more.
(7) Check that the slip indicator light comes on for several seconds and then blink in the test mode pattern (0.125 seconds on and 0.125 seconds off).
HINT:
* If the slip indicator light does not blink, perform zero point calibration again.
* The zero point calibration is performed only once after the system enters test mode.
* Calibration cannot be performed again until the stored data is cleared.
(8) Turn the ignition switch off and disconnect SST from the DLC3.
(c) Drive the vehicle straight ahead at 40 km/h (25 mph) or more for at least 10 seconds. (I was unable to do this task, just driving it around should be OK)
4. PERFORM DOWNHILL ASSIST CONTROL CALIBRATION (w/ Downhill Assist Control)
(b) Enter test mode (when using SST check wire).
(2) Using SST, connect terminals 12 (TS) and 4 (CG) of the DLC3.
Front view of DLC3
(c) Turn the downhill assist control switch off.
(d) Push the downhill assist control switch and check that the downhill assist control indicator light is blinking.
(e) Turn the downhill assist control switch off.
(f) Turn the ignition switch off.
(g) Check if DTC C120A is output.
HINT:
If DTC C120A is not output, calibration was performed successfully.
5. PERFORM CRAWL CONTROL CALIBRATION (w/ Crawl Control)
Front view of DLC3
(c) Push the crawl ON/OFF switch and check that the crawl indicator light is on while the switch is being pushed.
Text in Illustration
*1 Crawl Control Switch
*2 ON/OFF Switch
*3 Speed Selector Switch
*4 Low
*5 Medium-low
*6 Medium
*7 Medium-high
*8 High
(I pushed in the ON/OFF button while I turned the dial and kept pushed down till the end of the following steps)
(d) Turn the crawl ON/OFF switch off.
(e) Turn the speed selector switch to L (low).
(f) Turn the speed selector switch to medium-low.
(g) Turn the speed selector switch to M (medium).
(h) Turn the speed selector switch to medium-high.
(i) Turn the speed selector switch to H (high).
(j) Turn the speed selector switch to L (low).
(k) Turn the ignition switch off.
(l) Check if DTC C120A is output.
HINT:
As much as I tried using a pin method yesterday, I was unsuccessful the whole time. I spent over 4 hours on calibration and no luck. The way I was able to do this, by Autel Maxidas that my friend brought. Even then I was unsuccessful because I wasn't sure how to use it, it took some time, but I was able to calibrate it. Below, I will list certain options for Autel Computer, but it should be similar process for other units.
Solution (if you have a high grade DTC computer):
- hook up computer to your obd2
- choose your vehicle (make sure you select correct engine)
- you cannot erase this code, what you have to do is to test the system (Active Test option)
- turn ignition ON
- run the active test (I did it, without scanning the whole car, I chose Control Unit option)
- system will walk you through
- when test is complete, turn ignition OFF
- start your car
- put the car on Drive and go around the block
Sorry to bring back up a old post but have a question for the way you did the zero classification thing. I have a maxidas ds708 and followed your way but I can't get to the active test. When I click on control unit, it brings up a lot of options, so I click on the srs airbag but there is no active test option anywhere.
Greetings,
I have just become the lucky second owner of a 2014 FJ Cruiser Trail Teams Ultimate Edition (TTUE). The dash emblem that is on the car is the standard yellow "Trail Teams" one. I thought that the TTUE should have that silver one with the words "Ultimate Edition - Limited Production...
Hey Everyone,
I have a 2008 FJ Cruiser that needs new shocks and struts at some point. I have been told that there is cupping on my tires 2 different times.
I was thinking since I need new shocks and struts of investing in a 3inch lift kit, looking at various brands. That way when I need new...
