I’m not seeing any area for builds but have seen a couple other in this area so figured its best place to go. I feel a bit weird posting a Chevy in a Toyota forum but this car is a Toyota with a GM badge on it so I guess its ok.:grin:
So quick background I wanted something that was small cheap, would get good gas mileage and needed a bit of work to give me something to work on. I ended up buying this Prizm for $350 not really sure what I was getting into because it had no battery so I had no idea if it ran. The person I got if from was having clutch problems so she gave it to her brother with a new clutch to replace. The brother started on the clutch replacement and got hung up getting some bolts off and took some shortcuts removing cotter pins that involved a cutoff wheel. Realizing that he could not finish the job he put it somewhat back together and tried to move it to somewhere that could fix it. His put back together was just putting the wheels on without the CV shafts and when he went to move it the driver side tire barring got spit and the back of the barring got spun off the hub and the tire came off. The passenger side barring also was damaged but did not come out like the driver side. The car was then towed to a Midas to have them fix it but when quoted $1,200 just to replace the clutch plus an unknown amount to fix everything else damaged she gave up on it and decided to sell it.
Knowing this is really a Toyota Corolla and knowing the reliability and that there relatively easy to work on I bought it knowing it would be a bit of work to get it going again but hey I wanted a new project so jumped on it. After buying it I had to have it towed on a flatbed truck to my house where I started going through everything on it, go through the hardware that it had and taking it apart to figure out what was going to need to be replaced to get it driving again. I also got a battery and was able to get the electrical working so I could get the actual milage off the car. When I got it the kid said it was 95k something but was about 10k more
The first thing I did on it was pull the sub frame off and replace the two motor mounts that were cut off during the first clutch replacement attempt. I had to cut a small hole in the frame behind the driver side tire and cut off the most forward bolt because the weld nut on the inside of the frame broke off.
After the motor mounts were replaced I pulled the wheel assembly’s apart and replaced the barring in them as well as the lower ball joints that were damaged when the nuts were cut off.
Both wheel assemblies are back on the car now with the CV axles in. Both the CV shafts look new so I’m not going to replace them. The steering tie rod end also has damaged threads on it and I should have the new part on it sometime after it comes in on Wednesday. I also have new brake calipers coming as well, there brake pads and rotors look like they were replaced not that long ago however the rubber boot around the cylinder pistons are missing on the driver side and completely dry rotted and falling apart on the passenger side. I did have to go to the Toyota dealer yesterday to order a second cv axle nut because one was missing.
