1JZ-GTE motor swap
5.5K views 4 replies 4 participants last post by  Jzs147-RR
hi, i have a 1JZ-GTE motor with a/t tranny, all the electronics(RHD), and crossmember for motor and tranny, and was wondering what i can swap the motor in w/o heavy engine bay surgery. thanks
ok for simplicity of most part, out of what i have heard, i'm either going SC300, mkiii supra. b/c i have the crossmember from the original car that the 1jz come from, all the way from motor mounts to all 3 tranny support crossmembers.i also have the complete uncut wire harness, with ecu, and ignitor. original 1jz intercooler, and intake piping.
if i go SC300 what are the possible years on it?
if i go mkiii supra do i want MA70 or MA71?
i need to choose a body, upgrade fuel systems, and
my final Q is what do i need to do about a drive shaft on either body? cause i don't have one yet.
i have heard the sc300 swap would be the most resonable swap so i lean towards it, but i need to know what years i'm looking at
The sc300 model range is 1992-1999 if im not wrong and for the supra i would go with the MA71 since the 1jzgte versions of the supra where only available in 1993 to 1993.5 .the drive shafts will need to be custom and fuel is good enough for stock boost in both body types.
