Bank 1 Sensor 2?
17K views 5 replies 4 participants last post by  decru
I got a oxygen sensor go bad on me and Im wondering what Bank1 Sensor 2 means. There is only two o2 sensors from what I understand. Its a 2002 Chevy Prism (Toyota Corolla). Its Sensor 2 the one closest to the engine? Or is it the downstream one? :ugh3:
What is the error code? If it is what i am thinking it is the Mass airflow sensor. Do you have any hesitation or loss of power? Any stalling? How many miles do you have?
If you take it to Autozone they might have a OBD2 reader to get the code if your check engine light is on.
But my bet would be the MAF sensor, since I got the "bank 1 sensor 2" code p0171 i think... and it was the MAF.
If that is is it is about $70 plus core for the part and easy to replace. Located to the left of the air filter housing on the intake tube. Remove two screws. disconnect wire harness.
decru makes a good point, many times a CEL indicating a potentially bad O2 sensor is actually just a dirty MAF sensor. Many have reported good results with just cleaning the sensor and attached IAT (intake air temperature sensor). They make MAF safe solvents out there - CRC brand is pretty decent. Brake cleaner works too - just make sure it is the non-chlorinated variant.
But to your original query. Bank #1, Sensor #2 is the downstream (post) cat O2 sensor.
