tgidavid, why would the R154 be difficult? if you're swapping to the 1j, you might as well step up to the tougher gearbox.
Anyhow, if you currently have a W58, I'd use it. The R154 is the trans of choice as far as I'm concerned. The W58 will only take 350hp or a little more before it melts down, and upgraded clutches are tougher to find. R154 is pretty much unlimited power holding for the purposes of 99.99% of supra owners...
If you are staying non turbo, stick with the W58...no reason to change it as the non turbo will never make the power needed to break one.
