Trying to get some answers
1.3K views 14 replies 8 participants last post by  ted_bell
Please, can anyone tell me if there's a lot of difference between a corolla and a camry? I've noticed corollas are cheaper priced, but will they last as long, and maybe they're just not as fancy? Also, what is a corolla with a v6 engine in it called? Thanks for any help
Both are well made and should last for many years if properly maintained. The Corolla is smaller and (without researching exact terminology) is considered primarily a compact economy car. Camry is more of a family car -- larger, quieter, more comfortable than a Corolla. Also, you can get a Camry with 4-cylinder or V6 power, where Corollas are only available with 4-cylinder engines. Being smaller & lighter, expect to get better fuel mileage with a Corolla.
The difference between both cars is about $5,000.
If a manual tranny is a must for you, Corolla is your only choice.
I personally would go with the Camry. Larger smoother vehicle and safer all around.
Unfortunately neither come in wagon form.
The most basic difference is they are two different size classes. Going by the EPA, the Camry was compact up until 1992, and midsized from then until now. The Corolla was a subcompact until 1993, and from then is considered a compact. Camry was always the next price point up from the Corolla. A Camry competed with cars like the Accord and Taurus while the Corolla did battle with the Civic, Cavalier, and contemporaries. The Camry is thus longer, wider, and offers more interior and trunk volume, requiring bigger 4 cylinders and offering optional V6s. This typically makes it a better cruiser and better for families at the cost of gas mileage, being harder to park, is more expensive. A used Camry typically has more options on it than a Corolla and also features a little higher quality materials and better NVH tuning. On the plus side a Corolla will be a little cheaper to operate, use less gas, and probably a little more nimble. Insurance may also be less.
Both are built to the same standards and aside from minor year to year differences you can expect similar reliability. For similar cars at the same price (in terms of year/mileage/features) I would go with a Camry. The Corolla has a bit of a premium on it in due to it's reputation as a reliable gas saver that doesn't seem to be abating despite gas going way down that tends to not always make them the best value as a used car. The Camry has a great reputation too but they seem to offer more for the money used. That said drive both and see what you like, but if you compare say a 2010 Corolla to a 2010 Camry, the Camry will probably be a little nicer car. The only ones I know to avoid are a run of 5th and maybe 6th gen Camry that had issues with the 2.4L, and from 98 to around 04 the 1.8L in the Corolla also had oil burning issues.
That or the first gen Matrix/Vibe, which is less weird looking than the xB and offers either AWD or a sporty XRS (GT for Pontiac) model with the high revving 2ZZGE. I would pass on the second gen Matrix but the second gen Vibe isn't bad looking inside or out.
#13 ·
#14 ·
Right, better to keep all options open. xB2 has the same engine and would be roomier to boot. Added bonus, maybe not as many xBs were affected with the oil burning issues that plagued the earlier version of this engine.
