Had a rear sunroof drain on my GEN 6 become disconnected and fixed that. But in my case it was the driver's side rear foot well that was sloshy and the wet had travelled a bit up under the driver's seat. You'd be best off if you can store it in a garage over a weekend to fix this. I pulled out the driver's seat, both driver's side door sills, the driver's seat belt anchor bolt, the B pillar lower panel, the back seat lower cushion - basically anything that held down the carpet except the front center console. Doing this I was able to pull up the rear-most outer corner and a good portion of the outer edge of the carpet and pull out the padding that had been affected. I shopvac'd (using the pinched end attachment) the exposed wet carpet over and over until it seemed dry. Then I used one of those massive "binder" clips on the carpet's corner and strung that to the front pass oh-crap handle to keep that area of floor exposed and give hands free access to the edges of the next nearest pads (that I was unable to remove). I shopvac'd those pad edges well, then I snugged old towels at the edges of those next nearest pads and left them there to draw out additional moisture, changing the towels out if they became saturated. I took my shopvac to the pads I removed and ran the pinch attachment over each side relentlessly. I put binder clips on each of them and hung them from my garage rafters to let them hang/drip dry. Then I left everything overnight with both driver's side doors open. Checked the next morning and used the blow dryer on anything that seemed at all moist to the touch. Then left everything as long as I could and still leave me time to re-install all the pads and lay down the carpet enough to put back the driver's seat & seatbelt anchor bolt. I left the back seat, B pillar panel, and door sills out, leaving me with the ability to still pull up at least a bit of the carpet from that same rear-most outer corner. I drove it that way for a week, checking for moisture in the pads and carpet - my biggest concern being that I would end up locking up some moisture under the carpet and leave it no way to evaporate if I buttoned it all back up. I put it all back together the next weekend when everything seemed and felt dry.
tl;dr: it was a PITA and took way more time and effort than anyone wants to expend to just dry stuff out - but what are you gonna do?
