driver window rear clip separated from window. window rear side is out of track. the front clip is secured, window in track. is there a way to finagle rear side into track? i don't have access to either clip bolts. i can't move up/down now to align for bolt access. unless there's a special thin tool for when you can't move regulator. even if i could get a 10mm wrench in the front i might not have leverage to remove bolt. i can stick my arm in if special flat 10mm wrench exists. (i can't find searching if i can just pop the rear side back into track? everything i see says to pull the window up/out then back down into track. i need to remove the driver window front clip bolt with no access to it.??? i don't know if the out of track is my only problem, it's a symptom of a bad regulator? thanks for any advice!
ran motor, raised regulator on glass, before i realized the rear side is out of track
