Hey guys, this mod is easy-peasy, it replaces your stock fuel filter banjo bolt with a Schrader valve so you can use readily-available gauges to check your fuel pressure!
Special thanks goes to @Stretch86, who originally did this on his car. The replacement valve was for a 7.3 Powerstroke I think.
As always, you do this at your own risk, neither myself nor Toyota Nation will be held responsible for your shenanigans.
Parts:
- 17mm socket
- 11/16" deep socket
- 7/16" box wrench
- torque wrench
- M12 x 1.25 banjo bolt with 1/8" fuel pressure takeoff, Russell P/N 640700 (http://www.ebay.com/itm/231925233035?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT)
- 1/8" NPT flare to 1/4" male brass Schrader valve Riffraff Diesel P/N GZ-13-005 (http://www.ebay.com/itm/252592095821?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT)
NOTE: Do NOT use a Schrader valve meant for air or A/C; the internal seal will not resist gasoline and the valve will fail. Use a Schrader valve meant for fuel ONLY.
- Hylomar Universal Blue non-setting sealant or equivalent, Hylomar P/N HUB003 (http://www.ebay.com/itm/172211644418?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT)
Parts:
- 17mm socket
- 7/16" box wrench
- torque wrench
