‘00 Camry defrost not working correctly
1.9K views 3 replies 4 participants last post by  elomaea
I have a 2000 Toyota Camry LE 3.0 V6 manual. When I use the defrost, the air blows normally through the driver window vent and the vent by the windshield. The passenger window vent barely blows any air at all regardless of fan speed. Any thoughts or similar experiences?
On my 1999 Camry my blend door motor and mechanism got jammed due to wearing out I believe. So it was not diverting the air to proper places. If I remember it was stuck on defrost only. I had to purchase the part thru the dealer and replace it. Maybe cost under $200 I think. I suppose you could go to a junk yard and harvest this part, up to you. Sometimes you learn more at those junk cars on how it is installed. But the life of a junk part is sometimes unknown. Somewhat difficult a job to get it correct when reassembling the motor and blend door guide. Take note of all the things you do so you can reassembly it to work properly. The blend door motor is behind the center covers so you need to take some stuff apart and its up a ways on the drivers side right under there so get ready to stretch your body. Best of luck. Let us know what you find.
