My 01 camry is driving me nuts. Literally. I have a petsistant p0401 that refuses to go away. I think I have read every page here about how to resolve this. My camry dosent stall, hesitate, nor has bad fuel mileage...26 city and 34 highway at 145k miles
I have completed the following:
Cel on p0401
I removed the egr and cleaned. It only had black soot. I removed the exaust tube and cleaned...again only black soot. I checked the block where the tube attaches and it was clean. I ran a brush through it just to make sure.
At this time I cleaned the intake manifold...again just black soot however I did use seafoam and cleaned the crap out of it.
I made sure the vacuum ports was clean to the vacuum modulator.
I installed a new egr just to make sure that the spring had not become hard and verified that 4 to 5 inches of vacuum would kill the engine.
Cleared code on computer .,.5 mikes later...p0401 pending ...second key start and the cel on again.
Next was the vsv . I left the old one in place and replaced it with a genuine toyota. Prior to installing I bench tested it for proper operation along with a vacuum pump to verify operation. I must have cycled it 2 dozen times. I installed it on the intake and rerouted the electrical plug an vacuum lines.
Cleared the computer...5 miles pending p0401 ...second key start cel on again.
Next was the vacuum modulator...very easy to check... however I installed a new one anyway.
Cleared code same as before cel on after 2 key starts.
I have also changed the vacuum lines with metric lines...none are crossed or in the wrong place. I have verified that the under hood diagram and toyota manual.
Next I replaced the map sensor and hose connecting no change in the cel
My question is what am I overlooking .....
I have also replaced the upstream 02 sensor as I was informed it could be lazy....no change in cel.
I have vrtified that the vacuum
I have checked that the vacuum required to open the egr is in line with the manual for operation. The vacuum at the modulator is proper
Same as above cel on sfter 2 key starts.
I have even chsnged the upstream o2 sensor but to no avail.
What am I overlooking? Thanks for the input.
Cel on p0401
