02 avalon reverse lights and gear position dash lights not working
9.9K views 4 replies 3 participants last post by  BigAl0008
Check the 10A Gauge No. 2 fuse first, and then check the 5A ECU-ACC fuse next. If that is OK, short pins 3 to 5 in the relay that should be located behind the left kick panel. Turm the ignition to "on" for this test.
