Hi, all. My 2005 Camry's alternator has been making a funny whining sound, little battery light is on on the dash, and voltage at the battery posts is 12.1V when the engine is running. Battery is 1-1/2 years old, I charged it and it showed 13.8 to 14.1 volts when the charger was running. Now car starts fine, but the whine persists and battery voltage is still maybe 12.2V with the engine running. That says alternator to me - car has 180,000 miles on it.
Disconnected the battery negative post, got a serpentine belt tensioner, loosened the belt and slipped it off the alternator pulley. Then disconnected the wires from the alternator. Got the top bolt (holding the alternator) off, but could not for the life of me get a wrench on that smaller bottom bolt. Closest I can get is to round off the corners of the bolt, I try to avoid that. (An oddity: All the Youtube videos I've watched about replacing your 05 Camry, say that that bottom bolt is 12mm. But mine is 10mm. Was this car built on Mars?)
One problem is that the water pump pulley sticks up right in front of the bottom bolt. Neither open-end wrench nor box-end nor 10mm socket want to go onto the bolt straight and square. Yes, a 12mm wrench just spins freely, the bolt is NOT 12mm. On at least one of the Youtube videos, there seems to be maybe half and inch more clearance between the bolt and the water pump pulley. Curiouser and curiouser.
Was the guy in the factory who mounted alternators on new Camry engines back in 2005, easily and neatly, out sick from work that day?
Anybody else run into this problem? I believe the 02-06 (?) Camrys are pretty much identical to my 05.
Thanks all!
Thanks all!
