07 Camry won't go in gear *Solved*
Some times my 07 V6 LE won't go out of park. In some cases I can wiggle the wheel and get it to let me shift. In other cases I have to turn the key off and turn it back on. One time I did this three times and then the AC would not come back on and the amber light on the button for the rear window defrost blinked for about 10 seconds then the AC came back on. This all started about 90 miles after I turned over 60k (out of warranty). LOL !!!
Anyone know what is going on ?
With no help from the dealer I found the problem. The battery was going bad. Replaced the battery and the problems went away. Here is a list of the symptoms.
1. Shifter gate lock won't operate so you can't shift.
2. AC won't come on right away and amber light blinks.
3. Remove won't lock the car untill after many tries.
4. iPod adapter not working right.
5. Final clue.. car gets hard to start, takes longer then normal.
I should have known.. all my OEM batteries have gone out in the third year just as summer ends or during the first cold snap. If lots of things stop working at once that require 12 volts (not 11.2 or 5.6 during starts) then get a new battery or get it checked.
