120v switch/outlets
24K views 15 replies 6 participants last post by  2008toyotagirl
I have (two I believe) "120v" outlets. I'm confused though because they're standard lighter sockets. How are those used? Do I have a two prong 110 outlet somewhere? I know the newer HL's have that in the center console.
Is anyone using this feature on a Gen 2?
Bob
Discussion starter · #15 ·
ok, was thinking I could probably go slightly over spec on wiring if fused correctly but doesn't sound like it's worth the effort.
Discussion starter · #12 ·
is there actually a separate inverter that can be upgraded? It would be great to use the existing outlet and wiring.
thanks
Discussion starter · #9 ·
Ok, mystery solved. There is an AC outlet all the way in the rear on the driver side. It’s labeled “AC 115v - 100w“. It sounds like this is pretty much a non existent option. The original owner was a Toyota Exec and the guy I bought it from said it was a special order and had “every option” so it makes sense.
I’m not sure if I’ll need it but I’ll test it out and see if it works.
