$1500.00 Dollar flex pipe replaced???
1 reading
3.5K views 28 replies 18 participants last post by  lastminutelizzie
My shop left a message saying my great 2006 Toyota Solara needs to have the flex pipe replaced (due to a hole in it) at a cost of $1500.00. I'm guessing this procedure involves more than simply replacing the flex pipe. They did not mention replacing the cat as part of this procedure.
Does this seem legit. Anyone know what is involved?
There is no flex pipe under any car worth $1500. That price is more appropriate for your cost on an OE catalytic converter. You could buy a flex pipe from a farm & barn type store. If you have a Mills Fleet farm store not too far away, they have generic ones that you might be able to cut & clamp a new one in. Parts stores also carry flex pipes, but I do like Mills better. At the core, you have significantly cheaper options than that shop.
If they can actually justify that price, make them show it to you. If you absolutely have to let somebody else do the work, it probably shouldn't be these guys. Get other estimates from exhaust shops if there are any nearby.
#7 · (Edited)
The OEM part, they replace the whole section of pipe, and possibly your whole exhaust, surprise it doesn't cost more. That one section of pipe includes the CAT, so it cost a lot for OEM part. If rusted out, they replace a good chuck of the exhaust. An exhaust shop will cut out the flex pipe section only and weld on new one for a few hundred bucks. Dealer will not do this and replace whole pipe.
My 2005 is leaking in flex pipe section as well. I bought aftermarket parts for whole exhaust and will replace myself. Major leak in flex pipe section, leaking small amounts elsewhere. May I ask if your support bracket fell off? Mine, studs came off and the bracket from rust. Resulting in rattle sound.
Dealer uses OeM parts. The flex pipe only does not exist as an OEM part, so they replace at a minimum that whole section, that justified the cost. The section includes the CAT. OEM exhaust parts cost a lot. If the fasteners rusty, may have to replace sections.
$1500 sounds about right to me for OEM parts. Verify their claims. Use a shop vac, and put in muffler and blow air. Put hand on flex pipe portion. I felt a LOT of air coming out when I did this.
No
No man
Sh No
I believe you'd get your ass kicked charging me something like that
You should have a tire kid that will do sh like that for cash
Next time it's in for tires and up on the lift , get under there and talk it over with him
It's your car,access ,get the parts
Cash on the side
Believe me, the kids in these shops are all.for it ,just gota get past the manager ,or throw him a bone ,no body says no to cash
Nobody
#20 ·
You can get the section of pipe, goes from exhaust manifold to post catalytic converter for a short bit, for less than $200 from aftermarket. This is the four cylinder model, likely 2AZ-FE
The OEM part number is 17410-0A370 . Just FYI the bracket I circled in yellow, is the bracket I was talking about. The two studs rusted off completely and part number 17584B completely fell off my car. The dealership I went to, after getting frustrated throwing the parts cannon at replacing parts trying to diagnose the whining sound, they did not tell me that 17584B completely fell off. I discovered this myself, comparing the diagram to my car, and realizing something didn't look right.
The OEM part has a MSRP of over $1600, so your $1500 estimate from the dealership with labor, not bad at all.
However, this is just a steel pipe lol, so aftermarket is fine.
How's the rest of your exhaust system? At 17 years old, it's likely leaking elsewhere. My 2005 Camry, the nuts on the studs on the exhaust flange that go to this piece of pipe are in good shape, I don't think I will have issue getting them off. The rest of the nuts on the rest of the exhaust, not so much.
For about $200 you can have a shop weld in a new flex pipe only. Or for about $200 you can replace that whole section of pipe.
Do you or are able to do the non-welding work yourself? If your flanges are also leaking on either side of this pipe, might run you $400 if you have a shop do it. If you have flex pipe replaced and both flanges repaired at the shop, you could get that whole section of pipe for half the cost with brand new aftermarket parts. Might as well as just get brand new aftermarket part.
What I'm saying, replacing just the flex section, if the rest of the exhaust is in bad shape, probably doesn't make sense if you do the work yourself.
My exhaust is leaking at the flanges and around the muffler. So I'm going to replace post exhaust manifold onwards using aftermarket parts.
Whatever you do, I'd confirm that it's actually leaking before doing anything, if you can.
#21 · (Edited by Moderator)
Due to an injury, I won't be doing any work on my Solara for some time, but I really do appreciate the response and in depth graphics.
I wouldn’t let them do it right away. Try another shop or two. Something doesn’t add up, especially if you don’t have a service engine light.
Wow! The absence of a service light should have been the first thing to come to my mind. My car runs fine and the check engine light is not on at all. Thanks Man.
#26 ·
well i mean look at it like this. im getting tech. here lol the downstream sensor can only monitor leading up to it. it has no idea what's going on after the the sensor, so therefore it can not monitor it. also metal expands as it heats up so even it ya got a light when the flex heats up it will temp. seal it enough the light goes off until it flexes a certain way
#29 ·
it will only throw a code if the leak is before the downstream sensor and sometimes not at all if its in the flex section cause well, it flexes so it can temp. seal the leak
I know I'm late to this comment thread but maybe it will help someone in the future. I just replaced my flex pipe in my 2005 Sienna and it wasn't throwing a 420 code before, now it is. I'm troubleshooting it in another thread so I won't go into detail here. I had to replace an oxygen sensor when I couldn't remove it from the original section of pipe, so I'm hoping I just got a bad aftermarket sensor.
