1994 Toyota Camry, what mods are easy and whart mods can the stock engine/trans handle?
15K views 17 replies 11 participants last post by  CROYCE992
what can this car handle and what is practical?
Cold air intake will give you no gain at all
k&n filter will give you no gain at all
tricking the ecu for a richer mix will give you more power(3hp) for a short period of time, until the ecu corrects itself
a straight pipe may get you 5hp, but only under wide open throttle
Lightweighting(removing anything unessential) will give you the biggest gain.
What!?!
Sorry man, but I have to question the validity of this.
You're saying is that the fundamental power enhancers do not provide any gains - while actually, REMOVING non-mechanical parts will. (?)
Simple, modest gains can be achieved by increasing the air/fuel in combustion.
Cold Air is dense - the more dense air mixed with the right amount of fuel will prove gains
The faster you get the air/fuel in - you also need to get it out. A proper high-flow exhaust will do the trick.
These are your basic tuning additions. And after the $500 - 1000 you spent on them - you probably have gained about 8hp.
That being said - the less weight you have to haul - the better. However - there's not much you can really strip off a Camry
When all is said and done - just remember it's your car and the last say is your choice.
There's cams availabe from a non-turbo MR2, which uses the same engine. However, it's not cheap.
http://www.mr2.com/forums/na-5s-fe-3s-ge/Toyota-MR2-18714-info-my-webcam-5sfe-cams.html
Think about how much money you want to spend.
There's really not a whole lot out there for the 5S-FE. With this engine, you'll get more noise than any real power with intake/exhaust mods.
If you want to make this car fun to drive, your money and efforts are better spent on the suspension/tires. There's a a lot of possibilities for tires/wheels. You can change struts, change springs to lower the car, etc...
Acceleration is only part of the picture. Your car also needs to handle and brake well to be enjoyable.
Bottom line - Cams and turbos for this motor is not practical - simply because you can drop a V6 for the dame price with less the headaches of FI
Not to stray from the OP's inquiry;
Throw in a CAI, highfow exhaust system, performance tune-up, lower it PROPERLY (forget about adjustable coilovers or cutting springs) and upper and lower braces.
Rule number 1 - Do it right the FIRST time. This hobby is expensive as it is - theres no point going the cheap route "for now" just to spend more money to do it "the right way" later.
#9 ·
Boo. I hope I can go FI with this motor so I can blow away v6's at least by a small margin!
But I agree with pretty much everything said here :thumbsup:
#13 · (Edited)
you best friend will be the search function. but in short, keep yours to minimal engine mods(intake, exhaust) and spend more time on suspension. youll likely tire of that particular model and its limits and will likely seek another model or another more potent car all together. sorry for being negative about it but the 2.2 auto is about as bad as the options gets and ALOT of money has to be spent to make any substantial gains.
one thing the majority of us have come to accept is that our cars are by no means performance platforms. even the fast camrys are....well not that fast. with the exception of a few. even then they are still a camry. personally id suggest keeping the camry stock and healthy and get another car for a project....say maby a 240 sx:thumbsup:.
