I recently posted regarding my IACV leaking (it was not actually leaking) and got excellent advice from you guys- thanks. My problem has returned. My camry has 220000 miles on it and runs great BUT when the engine is hot, if I turn off the engine, wait a few minutes and then start it again, it idles quite rough and seems like the engine will stall. If I drive around for 45 mins or so, stop to get gas and then try to restart, the car idles quite low and appears to want to stall out.The RPMs drop to about 600ish. If I give it more gas, then it runs better. Recently, I cleaned the throttle body and the IACV and that seemed to help but the problem returned today. Within the past month I changed the PVC valve and set my idle alittle higher.Any suggestions on what to do next?
