Hello TN members,
2000 camry 4cyl, 140k is stalling after like 2-3 min of start. RPM spikes and then drops and stalls. I can start it right back up and may run for a min (either in drive or park) but then stalls.
No check engine light.
All maintenance up to date (recent maintenance: fuel filter replacement, spark plug replacement..3 months back)
I read in many forums that this could be a bad/clogged IAC valve. So I removed the IAC and it was looking ok, not too much clogged. I cleaned it properly, put a new gasket.
Tested the valve itself. It shows ~29Ohm resistance between B and other two terminals.
Applied 9v (had to work inside) between B and other connectors and can hear the click. Looking at the valve (the magnetic spindle looking thing), I see that it rotates but NOT closing completely when 9v is applied. Not sure it is supposed to be like that or it is because of 9v or that is the problem itself. Since I cleaned and put it back (thinking the good clean is going to fix it) I didn't take any pics.
Is my IAC bad? Anything else is going bad that can cause this stall? I hate stalls, people are driving so close and I almost got hit today when my car stalled.
Any help would be greatly appreciated.
Thanks
John
Thanks
John
