2000 Camry V6 with shorted Alternator wire to frame - What did it damage besides 100 amp fuse?
7.7K views 28 replies 9 participants last post by  no_common_sense
I'd roll the dice on it for a couple hundred dollars, but I'm very comfortable with electrical work. Agree $900 is too much, but for a few hundred you'll make money even if you end up parting it out.
Are those relays and fuses actually bad or did the outside just get burned from the hot alternator wire? If the latter, I would bet it just needs the alternator wire replaced and a new fuse.
Nice work! I really didn't think the whole car would be fried just from an alternator short, that just doesn't make any sense at all lol.
I'd start by figuring out which pin is which in that fuse box, and see if there is something in common between the pins that are most charred.
