My friend with a 2007 V6 Highlander is putting a sound system into his Highlander and he needed some more juice out of his dying 100 amp alternator to power it. After reviewing pictures and using AS-PL Rotating Electrics - Starter motors, Alternators, Parts for starter motors and alternators | AS-PL Sp. z o.o. (fantastic site) to compare, the Sienna alternator has a slightly different shape, but has the same mounting points and connector. I gave him the go-ahead and it fit perfectly! Part number is "DENSO 2100539" from RockAuto.
This is a direct fit for any vehicle that uses the 3MZ-FE engine, including the 2004-2007 Highlander. This alternator will bolt up to a 2001-2003 with the 1MZ if you're willing to make an adapter for the wiring harness. The 1MZ uses the older 3-pin design, whereas the 3MZ alt has the newer 4-pin plug.
