Hi Gang,
I know there are a lot of threads on this issue, but I'm having difficulty extrapolating from those threads to my problem.
Son was driving car on the highway, reports that the engine just quit. I brought out gas thinking it was empty (he rides by the seat of his pants below 1/4 tank). No start, after many cranks, decide to have it towed home. After several days of hunt and peck, I have an epiphany that maybe the timing belt broke. Indeed, it was shredded.
So, install a new water pump, cams and crank seals, and belt. No start. Code reader gives cam sensors errors, but replacing those was part of the hunt and peck diagnosis prior.
So I must be mis-timed/aligned. The questions I have are:
Is it likely the crank and cams are out of phase/sync due to the cranks w/o a timing belt?
Is it always the case that when the two cam sprockets are aligned with the marks on the backing cover that it's at TDC #1? Or can they be aligned and not at TDC #1?
Is there an easy and smart way for a simple home-gamer to tell when #1 is at TDC w/o digging out the #1 spark plug and buying another tool? I can do it, but, man, that's a lot more parts and connectors for me to screw up.
Thanks,
Jay
Thanks,
Jay
