So, I was changing the alternator on my 2007 Solara SLE Convertible 3.3L. I didn't disconnect the battery because I was in a hurry and wasn't thinking, I know "haste makes waste". Anyways, that power cable touched the oil dip stick and there was an electrical power snap sound, like the low crack when hear when you connect the battery. I disconnected the negative terminal on the battery at that point.
I moved on to swap out the alternator and belt without any issues. After reinstalling I used my aftermarket remote start to start the car and make sure the belt wasn't going to squeal and wake the neighbors up. Car started right up, no belt squeal and ran for about 30 seconds before it shut off. It restarted itself and did the same thing.
I was about to call it good, but I decide to start it from the key since it kept shutting off. So I got in the car, put my key in the ignition, turned the key to start it and nothing. The "Check Engine", "ABS" and "SRS" lights are lit up in Start key position. Nothing lights up in the Accessory key position. Almost I have a bluetooth ODB2 code reader in the car and it won't connect to Torque Tuner Pro to see if there are any codes.
Any ideas on where to start with this? When I try to Google Search "Check Engine/ABS/SRS lights are on", the results are for each of the lights being on, not all 3 at the same time.
Thanks in advance,
Brian
Thanks in advance,
Brian
